hi there
how to graph slave ports on RB450G? currently I see all slave ports traffic are zero.
thanks
hi there
thanks
No there is not by using the switch chip. When you use the “slave port” option it places the ports on the switch chip and the CPU never sees the switched traffic. Since it never sees the traffic it cannot graph it.
You can bridge your ports together to see this data, but then you will take a rather large performance hit by doing so since switching is all now being done in software instead of hardware.
You can try
/interface ethernet print stats interval=1s
