RB450G stopped recognizing an 8 GB Sandisk microSDHC!
Hello all,
Less than a week ago I installed an micro SDHC 8 GB on a RB450G for the Webproxy to cache onto.
Is seemed to be working just fine. However, I just logged into the router and I see that the disk is no longer listed - it’s gone.
Anyone has had this happen before? Can anyone help me?
Thanks!
check the sdhc card for errors. They can have bad blocks and if certain blocks are bad then the device will not be recognized.
It’s brand new… anyway this means to check it elsewhere or is it possible to check it from the router itself?
Regards,
