I have had strange problems getting a solid connection to my RB450G. I previously was able to connect without trouble. I made sure my connections are correct and they haven’t changed.
I have tried connecting with picocom, which wouldn’t establish a connection.
I also have used minicom, which after a long delay would slowly print lines. But i was unable to use the interface, and it had problems with new line characters. The latency was also extremely severe.
Do I need an RMA, is my cable gone bad? I used to connect with both picocom and minicom, without incident. I connected on the same computer, so I’m not sure what could have happened.
Any help is appreciated.
