rb450g with openwrt bricked
Hi all,
i flashed openwrt barrier breaker and i successfully booted it.
but looks like i configured some thing wrong with vlan in openwrt.
after reboot, i can’t ssh or telnet or ping 192.168.1.1 now.
so i tried to re-flash openwrt-ar71xx-mikrotik-vmlinux-initramfs.elf
i hold the reset button and plugin the power cable, released the reset button after the power led turned off, just like what i did before.
but this time, tftpd32 can’t send the file to router. the log shown:
DHCP: proposed address 192.168.1.55 [25/02 09:33:54.343]
Rcvd BootP Msg for IP 0.0.0.0, Mac E4:8D:8C:09:C3:0B [25/02 09:33:54.952]
DHCP: proposed address 192.168.1.55 [25/02 09:33:54.952]
Rcvd BootP Msg for IP 0.0.0.0, Mac E4:8D:8C:09:C3:0B [25/02 09:33:55.164]
DHCP: proposed address 192.168.1.55 [25/02 09:33:55.165]
Rcvd BootP Msg for IP 0.0.0.0, Mac E4:8D:8C:09:C3:0B [25/02 09:33:55.379]
DHCP: proposed address 192.168.1.55 [25/02 09:33:55.380]
Rcvd BootP Msg for IP 0.0.0.0, Mac E4:8D:8C:09:C3:0B [25/02 09:33:55.788]
DHCP: proposed address 192.168.1.55 [25/02 09:33:55.789]
Rcvd BootP Msg for IP 0.0.0.0, Mac E4:8D:8C:09:C3:0B [25/02 09:33:56.001]
DHCP: proposed address 192.168.1.55 [25/02 09:33:56.002][/size]
over and over again, no file was sent to router.
and after a while the device just reboot itself again.
could some one kindly help me with it?
what can i do now?
Since you’ve installed openwrt why are you asking for support here? Use openwrt forum.
Reinstall mikrotik through netinstall or tftp.
