RB450Gr3 VLAN WiFi problems
Hi, I have this work in progress to configure my RB450Gr3. I have create following VLANs:
Main-vlan 100
iot-vlan 101
guest-vlan 102
family-vlan 103
VLAN 101-103 have own WiFi and I use an unifi ap lite.
In main-vlan I have proxmox with, among other things, unifi controller. My first thought was that I would use main-lan as my own network and also run wifi on it. To be able to manage unifi controller and run other virtual machines from proxmox. But when I do, I do not get it to work. No ip address is shared from dhcp and I can only run it wired. Is it because it’s untagged? I have more questions but choose to stay here until I have clarified why I can not use the main vlan with WiFi.
An alternative is that I create another VLAN that will be able to communicate over all the other VLANs. How can I proceed after creating another VLAN? How do I get it to communicate with the others already existing. Especially with the main vlan where proxmox is located.
# apr/23/2022 21:19:20 by RouterOS 6.49.6
# software id = FQCH-LUB0
# model = RB750Gr3
# serial number =
add admin-mac=DC:2C:6E:53:3A:02 auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=family-vlan vlan-id=103
add interface=bridge name=guest-vlan vlan-id=102
add interface=bridge name=iot-vlan vlan-id=101
add interface=bridge name=main-vlan vlan-id=100
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLAN
add name=MGMT
add name=main-pool ranges=192.168.100.10-192.168.100.254
add name=iot-pool ranges=192.168.101.10-192.168.101.254
add name=guest-pool ranges=192.168.102.10-192.168.102.254
add name=family-pool ranges=192.168.103.10-192.168.103.254
add address-pool=main-pool disabled=no interface=main-vlan name=main-dhcp
add address-pool=iot-pool disabled=no interface=iot-vlan name=iot-dhcp
add address-pool=guest-pool disabled=no interface=guest-vlan name=guest-dhcp
add address-pool=family-pool disabled=no interface=family-vlan name=family-dhcp
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=100
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=100
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=101
add bridge=bridge comment=defconf interface=ether5 pvid=100
/interface bridge vlan
add bridge=bridge comment=main-vlan tagged=bridge untagged=ether2,ether3,ether5 vlan-ids=100
add bridge=bridge comment=iot-vlan tagged=bridge,ether5 untagged=ether4 vlan-ids=101
add bridge=bridge comment=guest-vlan tagged=bridge,ether5 vlan-ids=102
add bridge=bridge comment=family-vlan tagged=bridge,ether5 vlan-ids=103
add interface=main-vlan list=LAN
add interface=iot-vlan list=LAN
add interface=guest-vlan list=LAN
add interface=main-vlan list=VLAN
add interface=iot-vlan list=VLAN
add interface=guest-vlan list=VLAN
add interface=main-vlan list=MGMT
add interface=family-vlan list=LAN
add interface=family-vlan list=VLAN
add address=192.168.100.1/24 interface=main-vlan network=192.168.100.0
add address=192.168.101.1/24 interface=iot-vlan network=192.168.101.0
add address=192.168.102.1/24 interface=guest-vlan network=192.168.102.0
add address=192.168.103.1/24 interface=family-vlan network=192.168.103.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
add address=192.168.100.0/24 comment=main-dhcp-network gateway=192.168.100.1
add address=192.168.101.0/24 comment=iot-dhcp-network gateway=192.168.101.1
add address=192.168.102.0/24 comment=guest-dhcp-network gateway=192.168.102.1
add address=192.168.103.0/24 comment=family-dhcp-network gateway=192.168.103.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8,1.0.0.1,8.8.4.4
/ip dns static
add address=192.168.100.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="Allow main-vlan/MGMT access to all router services" in-interface-list=MGMT
add action=accept chain=input comment="Allow VLAN DHCP" dst-port=67 in-interface-list=VLAN protocol=udp
add action=accept chain=input comment="Allow VLAN DNS UDP" dst-port=53 in-interface-list=VLAN protocol=udp
add action=accept chain=input comment="Allow VLAN DNS TCP" dst-port=53 in-interface-list=VLAN protocol=tcp
add action=accept chain=input comment="Allow VLAN ICMP Ping" in-interface-list=VLAN protocol=icmp
add action=drop chain=input comment="Drop all other traffic"
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=accept chain=forward comment="VLAN Internet Access Only" connection-state=new in-interface-list=VLAN \
    out-interface-list=WAN
add action=accept chain=forward comment="Allow Port Forwarding - DSTNAT - enable if need server" connection-nat-state=dstnat \
    connection-state=new disabled=yes in-interface-list=WAN
add action=drop chain=forward comment="Drop all other traffic"
/ip ssh
set strong-crypto=yes
/system clock
/system identity
set name=RouterOS
/tool graphing interface
add allow-address=192.168.100.0/24 interface=ether1
add allow-address=192.168.100.0/24 interface=main-vlan
add allow-address=192.168.100.0/24 interface=iot-vlan
add allow-address=192.168.100.0/24 interface=guest-vlan
/tool graphing resource
/tool mac-server
/tool mac-server mac-winbox
Does it mean that when you connect something to ether2, 3 or 5, it works, i.e. gets address? And the problem is only with wifi on some connected device, where I’m not sure what exactly happens or should happen there? Because the config seems fine, you should have functioning VLANs as defined in “/interface bridge vlan”.
(1) You have a duplicate list LAN=VLAN, get rid of one or the other, since you use VLAN list the most in firewall rules, get rid of LAN one! The xtra list does nothing for you.
(2) What is the purpose of your dst port 67 rule in the input chain?? What service is the router providing that the LAN users need access to?
(3) The invalid forward chain rule should be after the forward chain established rule.
(4) The input chain rule for ICMP does not need to exclude WAN side,
(5) With all the VLANs identified in the interface list, you can get rid of bridge as a member.
(6) dont forget to ensure neighbours discovery is set to MGMT interface list and TOols mac server WINMAC server is set to interface list MGMT!!
