Configuration Summary
*RB450Gx4 configured using WebFig and QuickSet for default configuration
WAN interface is ether1
LAN interface is ether2 which is bridged for ether 2-5
IPv6 Installed configured for PD /60
Default IPv4 Firewall
Default IPv6 Firewall
Problem Statement
Wireless clients connected to UAP-XG progressively slows down to half the the internet connection rate (500-600 mbps), whereas wired throughput remains consistent at ~930mbps. The wireless internet slow down can be replicated by running speed test (1st test 860mbps, 2nd test 720mbps, 3rd test 500-600mbps). Once throughput is degraded, wireless clients randomly experience extreme service degradation down to 15-25mbps.
Workaround
Clean reboot of both router and access point restores wireless throughput to ~860mbps. Rebooting the access point only does not restore wireless throughput.
Additional Question(s)
IP > Address default LAN address is set to ether2 instead of bridge0. Is this correct?
Interfaces ether 2 - 5 are in bridge and in the switch. How can I verify the interfaces are using the switch chip and not software bridging?
If 2 -5 are in the Bridge, the IP address should be on the Bridge. The rb450gx4 default configuration puts the LAN IP address on “bridge”, you mention “bridge0”. Have you made a lot of changes? Perhaps post config … at least ip address / bridge / switch.
If you go to Bridge → Ports, you should see the “H” flag for hardware offload.
Correct. The Bridge is labeled bridge. It was a typo on my part from my Edgemax days where bridges are software and labeled br0.
The only changes from QuickSet are related to IPv6 configuration.
I changed the interface in IP > Addresses from ether2 to bridge.
It appeared to take the setting without issue, but WebFig is unresponsive when I went back to get the config. Traffic is routing just fine though. I’ve had this issue with WebFig from day one when I tried to enable ssh it would crash WebFig.
The throughput issue seems to be resolved. I updated the firmware on the UAP-XG to the latest stable build and also changed IP > Address > Interface to bridge from ether2. Not sure which one corrected the problem.
New Issue:
WebFig freezing appears to be related to using the logout in WebFig. Whenever I logout of WebFig it throws an error in red on the main landing page. Then I can’t log back into WebFig until I power cycle.
Although it can “work” (depending), assigning an IP address to an interface that is a member of a bridge makes no sense. Once an interface is a bridge member, it should not be individually referenced. Treat the bridge as one (logical) interface, at least when it comes to addressing.
@Nathan - Not sure how ether2 was the interface for the IP > Address as this setting was created by QuickSet. I’ll scrub my config later today to see if there are any other reference to a specific port vs bridge.
@proximus - It appears the WebFig issues is resolved in the release candidate. I prefer to stay with the stable release, but since this is a SOHO device and I don’t have any Windows clients I had to upgrade to rc66. Seems to have resolved the WebFig issue.
