Hi all
Could someone assist please? I have installed a RB493AH on a site running with 2x 12V batteries and a charger. I can’t see the voltage under the health tab. Is that specific model able to show voltage?
Hi all
How are you powering the charger ( AC supply ?)
I would not monitor the voltage from a Mikrotik board but instead I use stand alone voltage + current monitor to set voltage to 27V as required to float charge the batteries but cut-out of Mikrotik is about 28V, so correct voltage setting is very important also the meter i use gives me actual current consumption so up time on batteries can be calculated correctly.
Now, it have now voltage monitor onboard
U can use extern monitor like this but for 24 volts
http://www.wirelessinfo.be/index.php/mikrotik/pages/ups
