I have a RB493 and when I configure it as a bridge (only configuration is commands shown below) it drops anywhere from 5 to 30% of the packets passing through it. Sometimes the below message is also displayed in my windows ping:
reply from 192.168.35.3: bytes=1200 - MISCOMPARE at offset 959 - time=2ms TTL=64
When I replace it with another RB493 with the same config and all the cables in the same ports, everthing works fine.
I have done system reset and started from scratch, etc…
I have tried this running ROS v3.10 and v3.1344
Anyone else seen something like this?
-------------config---------------
/ interface bridge
add name=“bridge1” disabled=no
/ interface bridge port
add interface=ether1 bridge=bridge1 disabled=no
add interface=ether2 bridge=bridge1 disabled=no
add interface=ether3 bridge=bridge1 disabled=no
add interface=ether4 bridge=bridge1 disabled=no
add interface=ether5 bridge=bridge1 disabled=no
add interface=ether6 bridge=bridge1 disabled=no
add interface=ether7 bridge=bridge1 disabled=no
add interface=ether8 bridge=bridge1 disabled=no
add interface=ether9 bridge=bridge1 disabled=no
