RB493 switch chip
I’ve had to use an RB493 as a switch to replace a dead switch. I used eth2 as master-port and set eth3 to eth9 as slaves. It works as switch correctly with v6.12. BUT, i need to know which MAC is connected to which eth port of the RB493. The ARP table shows all MAC’s in the eth2 interface (as expected). The table at /interface ethernet switch host is empty.
Which is the proper way to get the MAC that is connected to each port?
I have never used switch chip before with any routerboard, so I don’t know if this could be a bug…
Thanks!
