I have a new RB493AH that I just upgraded to 5.5. Now it is hanging every time I try to reboot it. When I type /system reboot, the serial port says:
Rebooting...
Stopping services...
echo: system,info,account user admin logged out via local
Restarting system.
…then it sits there with the blue LED on and the green LED mostly on but flickering about once a second. Removing and reinserting power puts it back in the same state. The only thing that seems to work is removing power for over five minutes, then reinserting power, at which point it comes up as if nothing strange has happened.
/system check-installation is happy. I’m using a 12V 300mA wall wart, which should be sufficient for a router that isn’t actually running anything. I’ve appended some configuration details below. Do I have a bad piece of hardware?
/system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 system 5.5
1 advanced-tools 5.5
2 ipv6 5.5
3 security 5.5
4 routing 5.5
5 dhcp 5.5
6 ntp 5.5
7 ppp 5.5
8 multicast 5.5
9 routerboard 5.5
10 mpls 5.5
/system routerboard print
routerboard: yes
model: 493AH
serial-number: 279801AB6422
current-firmware: 2.29
upgrade-firmware: 2.29
