RB493G + 3 radio
I am new with routerboard.
could I do a setup RB493G + 3 radio ? does it work as 3x3 ?
any other setup work best ?
Thk,
Pat
You mean 3x wireless cards? If so, then yes, that can be done.
yes 3 MikroTik RouterBOARD R52Hn
has anyone already done the setup with 3 wireless card ? does it give a good performance ?
pat
Into what antennas
Also, what are you trying to do? 3x access point mode? site2site links?
I have no idea which antenna and how many, any suggestion ?
for home wifi
There is a huge difference between
  • One radio with 3x3 MIMO
  • Three radios with whatever
You can stick 3 radios in a RB493G, but you can’t do 3x3 MIMO with it as those cards are all miniPCI-e and the RB493G only supports miniPCI cards.
i am not sure 3 radio minipci can do configuration 3x3 or not, but I am sure it is not relate to pcie or pci
