I have 3 VLANs in my network. Problem is slow establishing connection between VLANs. For example, when users from VLAN 200 try to run some exe file from server in VLAN100, running takes to much time (about 40 sec.). Users from VLAN 100 wher is server, same exe runs at about 10 sec. What is the problem?
SW config:
[admin@MikroTik Glavni SW] > interface bridge pr
0 R name="VLAN200+LAN_AP" mtu=1500 actual-mtu=1500 l2mtu=1584 arp=enabled mac-address=D4:CA:6D:09:A3:89 protocol-mode=rstp priority=0x8000 auto-mac=yes
admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R name="VLAN300+Servis_AP" mtu=1500 actual-mtu=1500 l2mtu=1584 arp=enabled mac-address=D4:CA:6D:09:A3:89 protocol-mode=rstp priority=0x8000 auto-mac=yes
interface bridge port prin
Flags: X - disabled, I - inactive, D - dynamicINTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 LAN_AP VLAN200+LAN_AP 0x80 10 none
1 I Servis_AP VLAN300+Servis_AP 0x80 10 none
2 VLAN300 VLAN300+Servis_AP 0x80 10 none
3 VLAN200 VLAN200+LAN_AP 0x80 10 none
interface ethernet switch vlan pri
Flags: X - disabled, I - invalid, D - dynamicVLAN-ID PORTS SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
0 100 ether20 no yes no no none
ether21
ether22
ether23
ether24
sfp1
switch1-cpu
1 200 ether1 no yes no no none
ether2
ether3
ether4
ether5
ether6
ether7
ether8
ether9
ether10
ether11
ether12
ether13
ether14
ether15
ether16
ether24
sfp1
switch1-cpu
2 300 ether17 no yes no no none
ether18
ether19
ether24
sfp1
switch1-cpu
3 D 4095 switch1-cpu no no no no none
interface ethernet switch egress-vlan-tag pr
Flags: X - disabled, I - invalid, D - dynamicVLAN-ID TAGGED-PORTS
0 100 ether24
sfp1
switch1-cpu
1 200 ether24
sfp1
switch1-cpu
2 300 ether24
sfp1
switch1-cpu
3 D 4095
interface ethernet switch ingress-vlan-translation pri
0 ports=ether23,ether22,ether21,ether20 service-vlan-format=any customer-vlan-format=any customer-vid=0 new-customer-vid=100 pcp-propagation=no sa-learning=yes1 ports=ether9,ether1,ether2,ether3,ether7,ether5,ether4,ether6,ether8,ether10,ether11,ether12,ether13,ether14,ether15,ether16 service-vlan-format=any
customer-vlan-format=any new-customer-vid=200 pcp-propagation=no sa-learning=yes2 ports=ether17,ether18,ether19 service-vlan-format=any customer-vlan-format=any new-customer-vid=300 pcp-propagation=no sa-learning=yes
3 D ports=“” service-vlan-format=any customer-vlan-format=any new-customer-vid=4095 pcp-propagation=no sa-learning=no
Router config:
ip add pr
Flags: X - disabled, I - invalid, D - dynamicADDRESS NETWORK INTERFACE
0 ;;; LAN
192.168.1.1/24 192.168.1.0 VLAN 200
1 ;;; DMZ
172.16.1.1/24 172.16.1.0 VLAN 100
2 ;;; Servis
192.168.2.1/24 192.168.2.0 VLAN 300
