Hello, I have a RB493G that I’m trying to get working with PCC.
I have 2 new IPD-Slam connections from AT&T, they both seem to be connecting to the same subnet (108.200.248.###/22)
The internet works on the RB when I have one of these connections disabled, but dies when i turn the other one on. I think this is also the issue im having with getting PCC working.
Is there anything I can do to get this working with both connections??
I was looking at the same thing and had post on the forum here asking for the same and I don’t think it is possible just to be bonding those two connections. What you can do is to make some load balancing - or make a static route so specific IP’s on your lan use the second internet connection as gateway.
I was actually trying to do PCC on these 2 lines much like I’ve done w/ 4 DSL lines in the past. But when I set it up, nothing works.
ether1 → LAN has ip of 192.168.24.1
ether2 → DSL1 has DHCP’d address from AT&T 108.###.###.14#/22
ether3 → DSL2 has DHCP’d address from AT&T 108.###.###.15#/22
Setting your route to an interface doesn’t really work unless your using a PPP interface. So try the above replacing the 1.1.1.1 with your gateway. Your gateway should generally stay the same even though assigned by DHCP.
