Hello, greetings to the community!
was setting up a RB493, barely put the DNS IP’s and I went to the hotspot and believed by setup, the fact is that the throw the message you have created, this did not appear on the list.
disconnect the winbox and went back inside, actually not created, so I restarted and since then has refused to start, just launches the first beep, it launches the second.
observation I have is that you configure the hotspot anter you enter a hot empty SD memory (ie, without disconnecting).
Since then I am trying to reset without results, try restore by Netinstall but this one did not detect it, by clear rj45
Any suggestions?
