RB493G reboot problem when formatting SD card
This router ALWAYS reboots when formatting a SD card. I tried two different RB493G routers with 2gb and 4gb cards. Always reboot - watchdog. Any clues?
tested on 6.2 and 6.4.
SD Cards are working 100%! Really noone had this problem? It seems really very low chance of both RB493G being defective or is it?
Ok, there seems to be a bug which causes the router to reboot when formatting sd cards. You need to disable watchdog timer for the time formatting an sd card.
Command:
“/system watchdog set watchdog-timer=no”
