RB493G (v6) + microSD
I have RB493G with RoS 5.26. After an upgrade to 6.10 lost card MicroSD. in System-store - no discs. I rolled back to 5.26 card appeared.
Probably a bug
I have updated and rolled back several times - the same result
Remove the card from the router board.
Start the router board back on.
Stop the router board.
Plug the card back in.
see if it works now.
I did all strictly on the recommendation, but it did not help.
maybe a problem in the firmware (v6)
I tried v6.4,v6.6, v6.10,v6.11rc, but did not help
maby a bug report this to Mikrotik
make supout.rif and sent this to support@mikrotik.com
