RB5009 and/or S+RJ10 - Verizon FiOS - IPv6
So quick question - preferably Y/N:
Were you able to connect RB5009 to Verizon FiOS and have working IPv6?
Were you able to connect S+RJ10 to Verizon FiOS and have working IPv6?
Were you able to connect RB5009 using S+RJ10 to Verizon FiOS and have working IPv6?
Hopefully someone will say 3 times yes.
I have problem with getting proper service. I tried almost all things and in the end I want to eliminate my equipment and put it on Verizon.
I tried using S+RJ10 on RB5009 and it didn’t work.
I tried using connecting directly to RB5009 and it didn’t work
I found that some ONT have issues with Intel NICs and with IPv6 TCP Checksum Offload as per here: https://www.intel.com/content/www/us/en/download/19174/disabling-tcp-ipv6-checksum-offload-capability-with-intel-1-10-gbe-controllers.html but there is nothing I can do in MT about it. Just to check.
I know that there are some Android devices with same issue, hence my question if someone had similar setup working so I will know that this is problem with routing on Verizon side.
TIA
3 x Yes.
It was a routing issue with Verizon. IPv6 flies like a magic :slight_smile:
