I have a new RB5009 which I setup CapsMan on. I have 2 CAP xl ac plugged directly into it as caps, R1 and R2. Both are listed in remote caps on the RB5009, though ONLY R1 seems to be working. R1 has disappeared from WinBox and R2 is listed. After using NetInstall to reset R2 and even resetting it as a cap and reboot this happens.
Also, the caps are supposed to be able to daisy chained correct? When I plug R2 into R1 it just blinks eth1 and no wifi, then I have to reset again… Any ideas?
