Have got the RB5009 up and running using defconf and have some questions.
The First Time Configuration documentation, does’nt match the latest RouterOS, main change is there is no Local interface, so I used Bridge instead, is this correct?
Should any flow control be turned on the WAN or LAN side, or is it set by defconf?
I have UPnP enabled (mutiple PC gamers in house playing at all hours), where in the GUI can you see what ports have been opened via UPnP?
Is there an equalent of the OpenWrt Luci Overview ?
Performance exceeds previous routers used and I now see up to 1000Mbps download speed via 2.5gE ONT <=> 2.5gE WAN <=> 10Gbps SFP+ DAC <=> 2.5gE Switch <=> 2.5gE PC, a nice bump over 1gE limit.
So far the only thing not working is speedtest.net finding optimal server quickly, likely port 8080 not open.
