I set up OpenVPN according to the guide at https://blog.nmoleosoftware.com/index.php/2022/06/12/how-to-set-up-and-connect-to-an-openvpn-server-on-mikrotik-routeros-7/
I’ve created the certs, enabled the OVPN server on port 1194 UPD, created PPP config, created firewall rules, everything in the guide.
I don’t see traffic hitting the firewall rule (it’s #1 in the list). Nothing in the log files.
I’ve unplugged the mikrotik from the cable modem, plugged in my Peplink Surf and connected using my old profile on my phone. So UPD 1194 is open on the cox business network.
This has to be my stupidity. What did I do wrong?
Client says
“event: resolve”
“contacting::1194 via UDP”
“Event: WAIT”
"connecting to :1194 () via UDPv4
“Event: Connection timeout”
client config:
client
dev tun
proto udp
remote *********.com
port 1194
nobind
persist-key
persist-tun
tls-client
remote-cert-tls server
ca ca-cert.crt
cert client.crt
key client.key
verb 4
mut 10
cipher AES-256-CBC
auth SHA1
auth-nocache
connection-type password-tls
dev-type tun
password-flags 1
username <user1>
Config
# may/20/2024 19:37:09 by RouterOS 7.8
# software id = ****-****
# model = RB5009UG+S+
# serial number = **********
add admin-mac=78:9A:18:**:**:** arp=proxy-arp auto-mac=no comment=defconf \
name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=DMZ vlan-id=9
add interface=bridge name=Guest vlan-id=8
add interface=bridge name=IOT vlan-id=6
add interface=bridge name=MGT vlan-id=2
add interface=bridge name=PLC vlan-id=10
add interface=bridge name=Servers vlan-id=3
add interface=bridge name=Workstations vlan-id=4
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=10.90.1.50-10.90.1.100
add name=dhcp_pool2 ranges=10.90.2.10-10.90.2.100
add name=dhcp_pool3 ranges=10.90.40.10-10.90.40.100
add name=dhcp_pool4 ranges=10.90.10.100-10.90.10.150
add name=dhcp_pool5 ranges=10.90.60.10-10.90.60.100
add name=dhcp_pool6 ranges=10.90.80.10-10.90.80.20
add name=dhcp_pool7 ranges=10.250.1.10-10.250.1.20
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp_pool1 interface=bridge lease-time=5h name=dhcp1
add address-pool=dhcp_pool2 interface=MGT lease-time=5h name=dhcp2
add address-pool=dhcp_pool3 interface=Workstations lease-time=5h name=dhcp3
add address-pool=dhcp_pool4 interface=Servers lease-time=5h name=dhcp4
add address-pool=dhcp_pool5 interface=IOT lease-time=5h name=dhcp5
add address-pool=dhcp_pool6 interface=Guest lease-time=5h name=dhcp6
add address-pool=dhcp_pool7 interface=PLC lease-time=5h name=dhcp7
/ppp profile
add bridge=bridge dns-server=10.90.1.101 local-address=10.90.1.101 name=\
vpn-profile remote-address=vpn use-encryption=yes use-ipv6=no
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether3 pvid=4
add bridge=bridge comment=defconf interface=ether4 pvid=3
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface bridge vlan
add bridge=bridge tagged=bridge,ether5,ether7,ether8,ether6 untagged=ether2 \
vlan-ids=2
add bridge=bridge tagged=bridge,ether6,ether7,ether8,ether5 vlan-ids=3
add bridge=bridge tagged=bridge,ether5,ether8,ether7,ether6 untagged=ether3 \
vlan-ids=4
add bridge=bridge tagged=bridge,ether5,ether6,ether7,ether8 vlan-ids=6
add bridge=bridge tagged=ether8,bridge,ether7,ether6,ether5 vlan-ids=8
add bridge=bridge tagged=bridge,ether8,ether7,ether6,ether5 vlan-ids=9
add bridge=bridge tagged=bridge,ether8,ether7,ether6,ether5 vlan-ids=10
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=DMZ list=LAN
add interface=Guest list=LAN
add interface=IOT list=LAN
add interface=MGT list=LAN
add interface=PLC list=LAN
add interface=Workstations list=LAN
/interface ovpn-server server
set certificate=Server-cert cipher=\
aes128-cbc,aes256-cbc,aes128-gcm,aes192-gcm,aes256-gcm default-profile=\
vpn-profile enabled=yes protocol=udp require-client-certificate=yes
add address=10.90.1.101/24 comment=defconf interface=bridge network=10.90.1.0
add address=10.90.40.1/24 interface=Workstations network=10.90.40.0
add address=10.90.10.1/24 interface=Servers network=10.90.10.0
add address=10.90.2.1/24 interface=MGT network=10.90.2.0
add address=10.90.80.1/24 interface=Guest network=10.90.80.0
add address=10.90.90.1/24 interface=DMZ network=10.90.90.0
add address=10.90.60.1/24 interface=IOT network=10.90.60.0
add address=10.250.1.1/24 interface=PLC network=10.250.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add address=10.90.1.0/24 dns-server=10.90.1.101,8.8.8.8 domain=domain.com \
gateway=10.90.1.101
add address=10.90.2.0/24 dns-server=10.90.1.101,8.8.8.8 domain=domain.com \
gateway=10.90.2.1
add address=10.90.10.0/24 dns-server=10.90.1.101,8.8.8.8 domain=\
domain.com gateway=10.90.10.1
add address=10.90.40.0/24 dns-server=10.90.1.101,8.8.8.8 domain=\
domain.com gateway=10.90.40.1
add address=10.90.60.0/24 dns-server=8.8.8.8,10.90.1.101 domain=\
domain.com gateway=10.90.60.1
add address=10.90.80.0/24 dns-server=8.8.8.8 domain=domain.com gateway=\
10.90.80.1
add address=10.250.1.0/24 dns-server=10.90.1.101,8.8.8.8 domain=\
domain.com gateway=10.250.1.1
set allow-remote-requests=yes servers=8.8.8.8,4.4.4.4
/ip dns static
add address=192.168.88.1 comment=defconf name=inside.domain.com
add address=10.90.2.11 name=wlan
add address=10.90.2.11 name=wlan.domain.com
add action=accept chain=input dst-port=1194 in-interface=bridge log=yes \
protocol=udp
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input dst-address=10.90.1.101 dst-port=53 protocol=\
tcp src-address=0.0.0.0
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set winbox address=10.90.1.0/32,10.90.40.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add disabled=yes name=vpn
add name=schoenjo profile=vpn-profile service=ovpn
/system clock
set time-zone-autodetect=no time-zone-name=America/Phoenix
/system logging
add topics=ovpn,debug
add topics=ovpn,info
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes use-local-clock=yes
/system ntp client servers
add address=time.google.com
/system scheduler
add interval=1d name=schedule-noip on-event="# No-IP automatic Dynamic DNS upd\
ate\r\
\n\r\
\n:local noipuser \"zzzz\"\r\
\n:local noippass \"*****\"\r\
\n:local noiphost \"*******.domain.com\"\r\
\n:local inetinterface \"ether1\"\r\
\n\r\
\n:global currentIP\r\
\n:global previousIP\r\
\n\r\
\n:if ([/interface get \$inetinterface value-name=running]) do={\r\
\n :local currentIP [/ip address get [find interface=\"\$inetinterface\" d\
isabled=no] address]\r\
\n :for i from=( [:len \$currentIP] - 1) to=0 do={\r\
\n :if ( [:pick \$currentIP \$i] = \"/\") do={ \r\
\n :set currentIP [:pick \$currentIP 0 \$i]\r\
\n } \r\
\n }\r\
\n\r\
\n:if (\$currentIP != \$previousIP) do={\r\
\n :log info \"No-IP Updater: Current IP address \$currentIP is not equal \
to previous IP, update needed\"\r\
\n :set previousIP \$currentIP\r\
\n\r\
\n:local url \"http://dynupdate.no-ip.com/nic/update\\3Fmyip=\$currentIP\"\
\r\
\n :local noiphostarray\r\
\n :set noiphostarray [:toarray \$noiphost]\r\
\n :foreach host in=\$noiphostarray do={\r\
\n :log info \"No-IP Updater: Sending update for \$host\"\r\
\n /tool fetch url=(\$url . \"&hostname=\$host\") user=\$noipuser password\
=\$noippass mode=http dst-path=(\"no-ip_ddns_update-\" . \$host . \".txt\"\
)\r\
\n :log info \"No-IP Updater: Update change requested. Hostname \$host wil\
l be updated with \$currentIP\"\r\
\n }\r\
\n } else={\r\
\n :log info \"No-IP Updater: Previous IP address \$previousIP is equal to\
\_current IP, no update needed\"\r\
\n }\r\
\n} else={\r\
\n :log info \"No-IP Updater: \$inetinterface is not currently running, so\
\_therefore will not update\"\r\
\n}" policy=read,write,test start-time=startup
/system script
add dont-require-permissions=no name=Updatte-NoIP owner=admin policy=\
read,write,test source="# No-IP automatic Dynamic DNS update\r\
\n\r\
\n:local noipuser \"***\"\r\
\n:local noippass \"**\"\r\
\n:local noiphost \"***.domain.com\"\r\
\n\r\
\n\r\
\n } \r\
\n }\r\
\n\r\
\n\r\
\r\
)\r\
\n }\r\
\n } else={\r\
\n }\r\
\n} else={\r\
\n}"
/tool mac-server
/tool mac-server mac-winbox
