RB5009 Power consumption
How to check RB5009 self power consumption in ROS?
It seam like it shows only consumption of PoE connected devices.
[admin@MikroTik] > /system/health print
Columns: NAME, VALUE, TYPE
#  NAME                 VALUE  TYPE
0  poe-out-consumption  10.7   W
1  cpu-temperature      52     C
2  board-temperature1   51     C
3  jack-voltage         0      V
4  2pin-voltage         25     V
5  poe-in-voltage       46.3   V
[admin@MikroTik] >
You cannot check internally, only with external powerplug with measurement capabilities.
My RB5009 does about ± 9W (50% of all ports used, 1 SFP+ inserted (type S+RJ10)
That you, it is strange because in the documentation example for CCR1072-1G-8S+ it is written that there should be such field. Then why it is not available in RB5009.
[admin@MikroTik] > system/health/print
 #  NAME                VALUE  TYPE
 0  power-consumption   50.8   W
 1  cpu-temperature     43     C
 2  fan1-speed          5654   RPM
 3  fan2-speed          5825   RPM
 4  fan3-speed          5800   RPM
 5  fan4-speed          5750   RPM
 6  board-temperature1  29     C
 7  board-temperature2  28     C
 8  psu1-voltage        0      V
 9  psu2-voltage        12.1   V
10  psu1-current        0      A
11  psu2-current        4.2    A
Sure but RB5009 is not a CCR.
I guess the sensors are not there on the RB5009 board, they need to cut costs somewhere :wink:
The CCR1072 is slightly more “enterprise/datacenter” than a RB5009 which I consider “home user” or “small enterprise” grade equipment.
