I am facing an issue with my RB5009 and wondering if anyone else has faced anything similar.
After an upgrade or a power failure or a power loss the router fails to startup.
You have to manually remove the power and start it again and everything works fine after that.
Is your router running a recent ROS version (7.12.1 was stable for some time, 7.13 is newly released in stable). Is routerbot also upgraded (/system/routerboard)?
Hello.
I have a similar situation; my RB5009 also restarts as if there was a power outage (the device is connected to an online UPS). Downgrading to version 7.12.1 solves the issue. I hope they fix it soon.
Everyone reporting the issue:
have you made supout.rif right after the reboot (or use autosupout if it was generated) and made a ticket with support with supout included ?
FWIW I don’t see this issue on 2 RB5009’s I have.
One on 7.14rc2, the other is on 7.13.3.
