Rb5009 required daily reset
Hello
I had a hex s. Never had a problem. Never required a restart. Recently, i switched to rb5009. Upgraded to latest software and firmware. Manually installed the same config. Everything worked for a week.
Now, almost every day, some devices become unaccessible. They become accessible again after i reboot the router.
What can be the problem? How can i debug this? It feels like router stops routing after a while to certain devices, networks etc. has anyone experienced anything like this?
What does “manually installed the same config” mean?
I have 2 x RB5009 and have no issues at all. I think your config has some sort of problem.
I meant i exported from hex s. And line by line executed on rb5009. No fancy migration of any sort.
I know this is not usual and most likely not many people have to reboot for any reason. I am asking what may be a reason for it? How can i debug
Debugging is done by using the log (and extending specifiic parts to the log).
But a good start is to share your config (make sure there is no information in it): /export hide-sensitive
