Hello
Can anyone tell me the difference between these routers??
I need a router with 2.5gbe wan and the option of 10 gbe later on?? Will this work??
regards
Hello
regards
Are exactly identical, what change is exclusively the PoE parts.
Is the time than from 13 Feb 2022, you take a decision.
