I want to rebuild my network and replace some old hardware. Want to ask for any advice and thoughts about this setup.
Current setup:
- ONT (fiber to ether) from local Internet provider connected to old Ubiquity ER-X router
- router connected to Ubiquity USW-LITE-16-POE Switch
- two Ubiquity APs connected to switch over POE
- one surveillance camera connected to switch over POE
- 10+ ether clients (including Unraid - no heavy load there. Backups, local media via Jellyfin, bunch of docker services)
- 40+ Wifi clients (mostly IOTs)
Planned setup:
- ONT (fiber to ether) from local Internet provider connected to RB5009UPr+S+IN to 2.5Gb ether
- router connected to CSS326-24G-2S+RM via SFP+
- Ubiquity APs and camera connected to router to have POE available
- Have separate VLAN for IOT and block internet access to the internet
- Have separate VLAN for personal devices, and work devices (corporate laptops)
- Have separate VLAN? for guests
- 15+ ether clients (including Unraid - no heavy load there. Backups, local media via Jellyfin, bunch of docker services)
- 50+ Wifi clients (mostly IOTs)
- Would it be better to have POE switch instead of CSS326? I ask in terms of performance of RB5009, cause it have to handle all firewall rules, VLANs and also traffic from two APs and camera.
- Can you recommend SFP+ modules and cables?
- What do you think about that setup? Anything to consider or change?
