I have RB5009UPr+S+IN with PoE AP connected over Eth2. The AP works fine, but on the router only PoE light (orange one) of Eth2 is on, the green light is off. If I move the AP to any other port, the green LED lights up. I’m not sure if it’s been like that since I got the router, but I doubt it (I think I would’ve noticed). I updated the router to RouterOS 7.10.2 along with matching RouterBOARD FW but the problem persists. Is there a chance it’s a software problem or is the LED just dead?
Unplug your router of power. Then, plug the router and all leds should turn on. If you see that keeps off, it’s dead.
Regards.
Only PoE orange lights (on all ports) light up for a split second when plugged in. Status lights do not light up on any of the ports.
Ok, this model is different. And if you put it on Netinstall mode and try to plug in on different ports, no change?
Regards.
I just net installed it and no change, so I guess the LED is fried. Thank you for help
