Apols if this has been answered but I couldn’t find it anywhere here or on a quick google search.
I am interested in using RB5009UPr+S+IN as my main router for my home setup
Apart from the WAN which comes through a Nokia ONT, I will need 4 eth ports for desktops, printers and 3 eth for the antennas.
My only question is, can I activate PoE Out only on 3 ports and deactivate on the rest?
Previous experience with MK products is you can either activate all or non.
is this per port or a generic on/off for all port?
can i have OFF, port 1,2,3,4,5
and ON port 6,7,8?
the “per-interface” suggests you could do it as word suggest per port but I am looking for someone to confirm that this is the case before I buy the router
Yes. (there is always some confusion between interface and port, as they can be synonym or mean different things, as a matter of fact the single ports (or standalone interfaces) are changed under a /interface sub-menu.
/interface ethernet poe
set ether1 poe-out=off
set ether2 poe-out=off
set ether3 poe-out=off
set ether4 poe-out=off
set ether5 poe-out=off
the default is auto-on, so you don’t really need:
set ether6 poe-out=auto-on
set ether7 poe-out=auto-on
set ether8 poe-out=auto-on
BUT if you need to force power on, you do need:
set ether6 poe-out=forced-on
set ether7 poe-out=forced-on
set ether8 poe-out=forced-on
