for some time I’m thinking about using the RB5009UPr+S+IN as the router/firewall for my homelab and replacing my pfsense. With the actual licensing changes of pfsense+ I’m thinking about this even harder.
As I’m a beginner with Mikrotik devices I kindly ask for your opinion of using the RB5009UPr+S+IN as a replacement for pfsense.
Right now pfsense is used for:
basic firewall to get the networks up
4 vlans
4 dhcp server for the 4 vlans
2 vpn-client connections (wireguard)
1 zerotier
1 wan for the vpns and zerotier also
1 wan for streaming (gateway for streaming vlan) with individual dns-server
Can this be done by or with the RB5009UPr+S+IN with regards to the hardware etc.? Any other recommendation that is not breaking the bank?
Yes, RouterOS can do all this. You can choose whichever hardware you think best. If budget is a concern with the rb5009 then perhaps check out the L009UIGS.
Right now I do use a 500 Mbit/s connection from my ISP. For my homelan I do use 10Gbit connections. That’s one reason for me to use the RB5009 with its SFP±port.
With ‘breaking the bank’ I meant that it should not be that much more for the router…
