My router board firmware is as follows
routerboard: yes
model: "532A"
serial-number: "14FA01C7D22C"
current-firmware: "2.12"
upgrade-firmware: "2.12"
export of setup identifing information removed
apr/01/2008 09:37:31 by RouterOS 3.6
software id =
/ip ipsec proposal
add auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
name="default" pfs-group=modp1024
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
comment="" disabled=no forward-delay=15s max-message-age=20s mtu=1500
name="Hotspot_Bridge" priority=0x8000 protocol-mode=none
transmit-hold-count=6
name="Backhaul_Bridge" priority=0x8000 protocol-mode=none
set 0 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes
mac-address=00:0C:42:1A:10:10 mdix-enable=yes mtu=1500 name="LAN"
speed=100Mbps
set 1 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes
mac-address=00:0C:42:1A:11:11 mtu=1500 name="WAN" speed=100Mbps
set 2 arp=enabled auto-negotiation=yes comment="" disabled=yes full-duplex=yes
mac-address=00:0C:42:1A:12:12 mtu=1500 name="ether2" speed=100Mbps
add name="hs-pool-8" ranges=192.168.2.100-192.168.2.225
/port
set 0 baud-rate=auto data-bits=8 flow-control=hardware name="serial0"
parity=none stop-bits=1
/queue type
set default kind=pfifo name="default" pfifo-limit=50
set ethernet-default kind=pfifo name="ethernet-default" pfifo-limit=50
set wireless-default kind=sfq name="wireless-default" sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name="synchronous-default"
red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50
red-min-threshold=10
set hotspot-default kind=sfq name="hotspot-default" sfq-allot=1514
sfq-perturb=5
set default-small kind=pfifo name="default-small" pfifo-limit=10
/snmp
set contact="www.bob.com" enabled=yes engine-boots=72
engine-id="" location="Duluth, MN" time-window=0 trap-sink=0.0.0.0
trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=""
authentication-protocol=MD5 encryption-password="" encryption-protocol=DES
name="public" read-access=yes security=none
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name="memory" target=memory
set disk disk-lines=100 disk-stop-on-full=no name="disk" target=disk
set echo name="echo" remember=yes target=echo
set remote name="remote" remote=0.0.0.0:514 target=remote
/user group
add name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,!ftp,!write,!policy
add name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,password
,web,sniff,!ftp,!policy
add name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
boot-protocol=bootp cpu-frequency=399MHz cpu-mode=power-save
enable-jumper-reset=yes enter-setup-on=any-key
add address-pool=hs-pool-8 authoritative=after-2sec-delay bootp-support=static
disabled=no interface=Hotspot_Bridge lease-time=1h name="dhcp1"
/user
add address=0.0.0.0/0 comment="system default user" disabled=no group=full
name="admin"
add address=0.0.0.0/0 comment="" disabled=no group=full name="adamanti"
add address=0.0.0.0/0 comment="" disabled=no group=full name="stevew"
add address=0.0.0.0/0 comment="" disabled=no group=full name="Ethan"
set default authentication-types="" eap-methods=passthrough group-ciphers=""
group-key-update=5m interim-update=0s mode=none name="default"
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none
static-algo-3=none static-key-0="" static-key-1="" static-key-2=""
static-key-3="" static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity="LakesArea_BriarLake"
tls-certificate=none tls-mode=no-certificates unicast-ciphers=""
wpa-pre-shared-key="" wpa2-pre-shared-key=""
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name="default" nas-port-type=wireless-802.11 radius-accounting=yes
radius-default-domain="" radius-interim-update=received
radius-location-id="" radius-location-name="" rate-limit=""
smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
add dns-name="" hotspot-address=192.168.2.1 html-directory=hotspot
name="hsprof1" nas-port-type=wireless-802.11 radius-accounting=yes
/ip hotspot user profile
set default advertise=no idle-timeout=20m keepalive-timeout=2m name="default"
open-status-page=always session-timeout=6h shared-users=1
status-autorefresh=1m transparent-proxy=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.2.0/24 comment="hotspot network" gateway=192.168.2.1
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=yes allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2.4ghz-b
basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=""
compression=no country=no_country_set default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=no
dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s
frame-lifetime=0 frequency=2452 frequency-mode=manual-txpower hide-ssid=no
hw-retries=15 mac-address=00:15:6D:54:36:D6 max-station-count=2007
mode=ap-bridge mtu=1500 name="Pub24" noise-floor-threshold=default
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name="00156D5436D6"
rate-set=default scan-list=default security-profile=default
ssid="LakesArea_Wireless_NS" station-bridge-clone-mac=00:00:00:00:00:00
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no
wds-mode=disabled wmm-support=disabled
set 1 ack-timeout=dynamic adaptive-noise-immunity=yes allow-sharedkey=no
dfs-mode=none disable-running-check=no disabled=yes disconnect-timeout=3s
frame-lifetime=0 frequency=912 frequency-mode=manual-txpower hide-ssid=no
hw-retries=15 mac-address=00:15:6D:93:2D:A8 max-station-count=2007
mode=ap-bridge mtu=1500 name="Pub900" noise-floor-threshold=default
proprietary-extensions=post-2.9.25 radio-name="00156D932DA8"
ssid="LakesArea_Brior-900" station-bridge-clone-mac=00:00:00:00:00:00
set 2 ack-timeout=dynamic adaptive-noise-immunity=yes allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=5ghz
basic-rates-a/g=6Mbps burst-time=disabled comment="" compression=no
country=no_country_set default-ap-tx-limit=0 default-authentication=yes
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none
frame-lifetime=0 frequency=5765 frequency-mode=manual-txpower hide-ssid=no
hw-retries=4 mac-address=00:15:6D:54:BA:5F max-station-count=2007
mode=bridge mtu=1500 name="BL-Backhaul" noise-floor-threshold=default
proprietary-extensions=post-2.9.25 radio-name="00156D54BA5F"
ssid="BL-Backhaul" station-bridge-clone-mac=00:00:00:00:00:00
tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150
wds-default-bridge=Backhaul_Bridge wds-default-cost=100 wds-ignore-ssid=no
wds-mode=dynamic wmm-support=disabled
add bridge=Hotspot_Bridge comment="" disabled=no edge=auto external-fdb=auto
horizon=none interface=Pub24 path-cost=10 point-to-point=auto
priority=0x80
horizon=none interface=Pub900 path-cost=10 point-to-point=auto
priority=0x80
add bridge=Backhaul_Bridge comment="" disabled=no edge=auto external-fdb=auto
horizon=none interface=WAN path-cost=10 point-to-point=auto priority=0x80
horizon=none interface=BL-Backhaul path-cost=10 point-to-point=auto
priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-vlan=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.0.1/24 broadcast=192.168.0.255 comment="" disabled=no
interface=LAN network=192.168.0.0
add address=192.168.2.1/24 broadcast=192.168.2.255 comment="Hotspot Radios"
disabled=no interface=Hotspot_Bridge network=192.168.2.0
add address=192.168.2.2/24 broadcast=192.168.2.255 comment="" disabled=no
add address=198.168.27.87/28 broadcast=198.168.27.95 comment="Change to Charter
IP" disabled=no interface=WAN network=198.168.27.80
add address=192.168.4.4/24 broadcast=192.168.4.255 comment="" disabled=no
interface=Backhaul_Bridge network=192.168.4.0
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 primary-dns=68.115.71.53
secondary-dns=24.196.64.53
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules
here" disabled=yes
here" disabled=yes
add action=masquerade chain=srcnat comment="Masquerade Local Network"
disabled=no dst-address=0.0.0.0/0 src-address=192.168.0.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network"
disabled=no src-address=192.168.2.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no
set pptp disabled=no
/ip neighbor discovery
set LAN discover=yes
set Pub24 discover=yes
set Pub900 discover=yes
set Hotspot_Bridge discover=yes
set Backhaul_Bridge discover=yes
set WAN discover=yes
set ether2 discover=yes
set BL-Backhaul discover=no
/ip proxy
set always-from-cache=no cache-administrator="webmaster" cache-drive=system
cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080
serialize-connections=no src-address=0.0.0.0
/ip proxy access
add action=deny comment="block telnet & spam e-mail relaying" disabled=no
dst-port=23-25
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0
gateway=198.168.27.81 scope=255 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=yes port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/queue interface
set LAN queue=ethernet-default
set Pub24 queue=wireless-default
set Pub900 queue=wireless-default
set Hotspot_Bridge queue=default
set Backhaul_Bridge queue=default
set WAN queue=ethernet-default
set ether2 queue=ethernet-default
set BL-Backhaul queue=wireless-default
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970
00:00:00" time-zone=-05:00
/system console
add disabled=no port=serial0 term="vt102"
/system health
set fan-mode=auto use-fan=main
/system identity
set name="LakesArea_BriarLake"
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=192.5.41.41 secondary-ntp=0.0.0.0
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0
secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=no no-ping-delay=2h
watch-address=192.168.4.3 watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=10
/tool e-mail
set from="<>" server=0.0.0.0
/tool graphing
set store-every=5min
/tool mac-server
set FIXME disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only
filter-stream=yes interface=all memory-limit=10 only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00
frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no
streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip hotspot
add address-pool=hs-pool-8 addresses-per-mac=2 disabled=no idle-timeout=20m
interface=Hotspot_Bridge keepalive-timeout=5m name="hotspot1"
profile=hsprof1
/ip hotspot service-port
/ip hotspot user
add comment="" disabled=no name="admin" password="nade" profile=default
add comment="" disabled=yes name="demo" password="demo" profile=default
/ip hotspot walled-garden
add action=allow comment="Radius Bypass" disabled=yes
