Rb532 @ 333Mhz how?
Hi Guys
How would I get my to rb to 333Mhz, is there a command for that?
You can try..
/system routerboard settings set cpu-frequency=333MHz
/system routerboard settings keep-frequency
Sometimes it will not keep the speed to 333MHz. I’ve had to try multiple times before it would work, and sometimes setting it in the bios using a serial cable is the only way to make it save..
-Gerard
  1. set
  2. reboot
  3. save
RB532r5 could be set at 400MHz :sunglasses:
I try some method and the workin’ is:
1, set cpu frequency
2, keep-frequency
3, reboot with power down and up!
when simple reboot with reboot command than te board will keep the original frequency.
Unfortunately I win only 2-3 plus megabit, so I think the cpu tuning is not the good way, I need buy a stronger board.
