RB532 BoardTest only 20Mb/s ,why ?
If we are ISP 1 >=20Mb/s Can use this Rb532 ?
how did you test it? You should run the bandwidth-test through the router and not from the router where you are measuring the speed as the BT takes 100% of CPU for generating the packets.
And what did you test?
Ethernet throughput?
Wireless?
Bridged?
Routed?
Best regards,
Christian Meis
PC----ethernet—RB532
PC run Windows BoardTest
