RB532 cannot ping itself
I have 2.9.38 soft and for some reason one AP lost IP connectivity.
I can access it thru mac-telnet but not via IP. It has IP address on ether1 interface and i cannot even ping that from the AP.
Has anybody encountered that ?
please check your configuration.
the configuration is fine. This problem appeared suddenly. We havent changed anything. The ethernet port works fine otherwise I wouldnt be able to do mac-telnet into it.
yes,
last way i think, you must put down from your tower and try connect with serial cable than check your firewall policy......
tree weeks ago, i called the welder for open my router :wink: :wink:
peace all
regards
Hasbullah.com
so, ip address is ok, and everything is ok in /ip route also?
when you check for mac-telnet - does it show ip adress, or nothing?
