RB532 not booting
This is all I’m getting out of an older RB532 via the console cable. The unit was working when pulled from a production site. The site was upgraded to a P4 based rack mount MT router for capacity/expansion requirements.
What is the best method to restoring this board or should I just send it in for repair?
Thanks,
Brad
RouterBOOT booter 1.2
RouterBoard 532
CPU frequency: 333 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
/etc/rc.d/rc.sysinit: 23: cannot create /var/run/utmp: Cannot allocate memory
System halted.
you can try to install latest routeros with netinstall
For really hard-to-get-rid-off problems I’d suggest
  • first formating the NAND from the BIOS of the RB532
  • then netinstall the desired firmware version onto it
This has just today helped me to get a RB532 back that was just rebooting randomly, but constantly (i.e. uptime of between 0 and 20 seconds, then rebooting). In some other cases that has helped, too.
By formating the NAND from the BIOS you will NOT loose your license!
Best regards,
Christian Meis
