RB532 nothing but blinkink leds !
I have a 532 board , when you power it the two bottom led and the ether1 leds are blinkin, blinkin and just blinking! tried serial connecttion , nothing! tried ethernet computer doesnt communicate the board, just blinkin once a sec. or two. any ideas ?
so when you connect using serial console, and turn board on, there is nothing on the output?
if there is output, or you manage to get into routerBoot configuration, then set it up to boot from ethernet and try netinstall.
http://wiki.mikrotik.com/wiki/RouterBOARD_Troubleshooting
noo normish nothing changes, i have checked that page before posting, i d better contact support.
Hi!
I have the same problem with a rb532.. any solution?
can I repair it?
AUTOREPLY: CHANGE THE 48V adaptor and it should WORK FINE ; )
thanks,
Martin
There is problem description and possible solutions.
http://forum.routerboard.com/viewtopic.php?f=3&t=3656
I have one more solution but it’s more complicated.
