Turn on PPTP logging on the MT. What shows in the log for a failed connection?
Regards
Andrew
Regards
Andrew
What happens if you connect locally from the LAN?
Regards
Andrew
Are you using dual gateways, or multiple IPs on that interface? Are you using named interfaces (by user) for the users to connect to, or the dynamic entries? Is it an issue with more than 1 pptp tunnel going thru NAT ? (GRE)
Sam
