RB532 + RB564 + Six SR2 ????
RB532 + RB 564 + six sr2
Will it work at maximum power ?
Can someone say it for sure ?
Six SR2’s is absolutely above the maximum electrical power the RB500 can provide…
Search the forum for relevant threads - this has been discussed here and on http://forum.routerboard.com, too.
Best regards,
Christian Meis
48V power over ethernet won’t help ?
Nope, RB500 series will support a recommended maximum of two SR2/5 cards. It’s the limitation of the miniPCI slots.
That´s right.. 2 cards MAXIMUN, using 48V and 30W powe supply…
Regards
Please ciber, have u tried 2 SR2 on a RB500 before and did it ork perfectly.becuse this the main problem i have with a network design for a client of mine.
4 cm9 cards work without problem!
2 SR2 cards are maximum for RB532!
I never tried two SR2 and two CM9 in RB532 so I can’t give you any advice about that configuration.
Cheers…
hello all,
i have a new client that already is already WISP using 2.4 GHZ platform with YDI radios with this he has ydi CPE radios in stock… but he want my me to build a back backhaul link for him on 5ghz and later distribute again with 2.4 ghz. so i want to use rb530/2x sr2. with 2x 180 degree sectors or 4x 90 degres sectors with splitters.
my main concern is: how effective are 2 of SR2 cards on RB532 ?
how effective will it be to split one card into 2x 90 degress sectors
will 2x SR5 cards be effective too
I have tried 1 SR2 + 1SR5 on RB532, and its working fine
Regards
I have a few set up
532 + SR5 and CM9
532 + SR2 and SR2 (on low output) and CM9
532 + SR5 and SR2
512 + SR2 and SR2
512 + SR2 and prism 200mw
All seam to work ok, but the 5.8 links are taking a bit to get sorted 100%
Back when the SR2 first came out I tried 4 and a CM9 and killed it. I have learnt from my mistake. :blush:
Like everyone says 2 Max
hello sirs,
thanks for the responses, please what if i try to use 2x sr2 and 1 x cm9 to achieve 3 sectors at 120 degrees
has anyone tried it that way ?
I don´t recommend you that… only if you power down one of the SR…
Regards
