When uploading the upgrade package to RC4 (was the some for RC1) to a RB532 over the local LAN (100 MBit) I get a constant upload rate of around 4.2 kb/s (!!!). So upgrading takes about half an hour.
Has anyone else seen this behaviour? this can’t be normal, or???
very strange. must be something specific in your case, cause i have never seen it and it seems noone else has this. see what happens after the ipgrade completes. try uploading something then
I’ve seen performance problems like this when there is a duplex mismatch (full vs. half, one side doing auto-neg, the other not) on the ethernet (not RB500 specific, just in general).
Yeah, seen that, too. But this port (haven the really slooooow transfer rate) has been connected to nearly everything I have that can speak Ethernet: different switches and hubs, 10-BaseT, 100Base-T autonegotiation and not, directly to different PCs, …
So that makes a real good candidate for a hardware problem
