I have been running this rb532 without issues for that past few months. Today the device stopped reponding on ether1. I was able to connect to it from the other ports. I looked at the logs (nothing but dhcp junk there) and the port showed that it was ok.
I recently upgraded it to 2.9.22. mainly because of this in the changelog
+fixed bug - rb500 had problems with ether1 interface (in 2.9.21)
What I was wondering is how can I setup the device so I can find out why it stopped reponding on that particular port if possible. Also if this has happened to anyone else.
Thank you in advance.
Also noticed that I can’t do this:
/system show-license (should I be able to?)
What's new in 2.9.21:
*) added "/system show-license" command;
