RB532, Wireless bandwith 5Ghz
Some stupid questions about RIC/522
Is it only 20Mhz bandwith in 5Ghz band?
I got the 5Ghz 5Mhz, 5Ghz 10Mhz and the setting that is called just 5Ghz, i guess this is 20Mhz bandwith?
Is there no 40Mhz wide 5Ghz cannel?
5Ghz is the standard 20Mhz channel.
If your wireless card supported 40Mhz channel you would have a 5Ghz-turbo listed.
According to this document from Mikrotik, I would expect your package to support Turbo.
http://www.mikrotik.com/pdf/ric522.pdf
-Louis
