RB532A and Kingston CF 1 GB
I have an RB532A (with RouterOS v3.x and Level 4 license) which I would like to enable its WEB PROXY service and taking advantage of the KINGSTON CF 1 GB for the cache.
  1. How do I know that MT recognises the CF availability ?
  2. How can I make this CF for the cache ?
Using the Winbox, I tried to check and format the CF. But it seems nothing happen at all.
Thank you
what do you mean by “nothing happened” ?
You need to set up the drive in the “store” menu, in the “drives” section:
and then set Webproxy to use the new Disk in the Store menu.
Hi NORMIS,
I have solved the problem as SERGEJS sent me an email.
It is solved as I upgrade my RouterOS to v3.1.8
Anyway, your version is v3.1.9.
From where can I download it ??
Which menu in the WinBox that I can get such STORE DISK ???
It is cool…
Thanks and cheers
as you see, fourth menu from below is “Stores”
