I have RB532A with RouterOS 3.22 .. I updated to v3.30 .. updated my license too .. i also checked for any available upgrade for the firmware but i found that i have the latest firmware so i didnt do anything .. I tried to upgrade to Router OS v4.2 then i found that the routerboard isnt booting anymore.
I installed Hyper Terminal but it tells me to dial a number !
I also cant connect using ip address since its not showing .. I only can hear the routerboard when it starts but i cant hear it when the routeros starts .
is there any manual for connecting to routerboard through HyperTerminal?
I tried to test the Hyper Terminal Program and the settings you told me about was its default settings .. seems like it stays connected like i can connect and disconnect anytime whether the routerboard plugged or not plugged .. is it normal ?
Or i have a different cable !
I plugged the cable into the routerboard and i found that the terminal program stays conected forever so there is no need to turn the routerboard off or on .. I used to work on the RC CABLE for updating my satellite receiver and it works .
