RB532a kernel panic on the firt power on
I have de “kernel panic” from the rb532 on the newer roterboard.
Console log:
RouterBOOT booter 2.9
RouterBoard 532A
CPU frequency: 399 MHz
Memory size: 64 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Break instruction in kernel code in traps.c::do_bp, line 592:
$0 : 00000000 10008400 00000029 00000000 802a38d0 00000001 00000001 802a38e8
$8 : 00000b66 00000001 802e0000 00000b67 802e0000 802e0000 802e0000 0000000a
$16: 802fea34 802fe8b4 00000001 00000000 802d4178 000000ad 000000f1 0000004e
$24: 00000002 80309e1b 80308000 80309f08 802d0000 801d64fc
Hi : 00000000
Lo : 08000000
epc : 801d64fc Not tainted
Status: 10008403
Cause : 10800024
PrId : 0001800a
Process swapper (pid: 1, stackpage=80308000)
Stack: 802a0000 00000100 00000000 0000000b 8026d174 80113978 801bedf4
801bef90 802fe8b4 80300000 80300000 80720000 80720000 80710000 80720000
04000000 0002c463 801d97d8 8028f1c4 00000001 00000000 00000000 80295dcc
80295de8 00010f00 8027e758 0002c463 8012528c 80166524 00000001 801017b8
00000000 8027e7a8 8027e7a0 00010f00 80720000 80720000 80710000 801017c8
04000000 …
Call Trace: [<8026d174>] [<80113978>] [<801bedf4>] [<801bef90>] [<801d97d8>]
[<8012528c>] [<80166524>] [<801017b8>] [<801017c8>] [<801017b8>] [<801058ac>]
[<80113978>] [<80268c9c>] [<80186674>] [<8010589c>]
Code: 3c048027 0c045479 2484c954 <0000800d> ae2000f0 8e0400ac 8c82000c 1040000e 00009021
Kernel panic: Attempted to kill init!
Try running a memory test from the bios. If the memory test passes try reinstalling routeros with netinstall. If the memory test fails then it is a bad board.
-Gerard
I have no problem with memory test, its all OK.
The routeros reinstall using netinstall was made, but after this the boot freeze on the “services startup”.
Any sugestion ?
thanks
Have you tried using winbox to find it after it says starting services? I’ve seen serial port settings not being correct cause it to hang there. If winbox doesn’t see it I would try doing format nand from the bios and doing a netinstall one more time. If it still freezes up I’m not sure what else to suggest except..
-Gerard
