[rb532a] top yellow and orange leds are flicking
I noticed that top yellow and orange led are interchangeably flicking in 1s interval
i cant find any info about in manual, where i can find any led codes table for rb532 ?
p.s.
i don’t have any script or settings that change led behavior
[admin@urbiszcze] > /system leds print
Flags: X - disabled
 #   TYPE                     INTERFACE                   LEDS
edit:
router board is working and fully functional
also i’ve got 2 mpci cards
Check /system script.
:led command is used on RB532A to operate LED.
as i said earlier i don’t have any scripts
[admin@urbiszcze] > /system script print
Flags: I - invalid
after googling i found that these leds are for mcpi cards but what it means ?
after disabling interfaces it still flicking
Yes, correct.
Few wireless chipsets reported additional information to RouterBOARD drivers and blinking LED is activity on wireless interface.
ok,
i’ve got Compex WLM200NX (down slot) and RB52 (upper slot)
either they are disabled nor enabled leds are flicking
where i can find what it means ?
