rb600 3xr2 1xr5
Hey i wanted to know what power supply you guys suggest for this situation
rb600 with daughterboard
3 xr2
1 xr5
Im currenly using a 48i http://www.streakwave.com/Itemdesc.asp?ic=POE-48i&eq=&Tp=, that puts out 16.8 watts , i have upgraded the firmware on the rb600 but i still get spuratic reboots, im wondering if i am underpowering or if this is just a crap board. And should i spend the extra on a power supply if the board is still just gona reboot.
How much does the board and daughter board take , and how much can it give to the cards?
How much power does a xr2 and xr5 draw?
4 XR cards are consuming ± 24 W, which is actually close to the maximum of watt, RouterBOARD 600 can give for the wireless cards.
RB600 consumes 9W by itself.
OK i just bought a power supply with 60w at 48v , and this thing is still rebooting, i even have the new firmware updates. RMA? Is there a fix i can download?
Make sure there are default settings for the wireless cards.
they were default to begin with and i changed them to try and lower the power consumption. Took em back to default and no change. Still reboots , clients still get kicked off. I have about 15 aps in production with 433s and 532, all of them have 50d uptime or better, the rb600 just reboots constantly
sounds like another defect unit of RB 600’s
http://forum.mikrotik.com/t/rb600-make-reboot-every-day/19536/1
