Hello
I have a PTP-link with 802.11n, RouterOS 4.0Beta4, as AP-Bridge with wds, hardware is RB600A, that is rebooting itself from time to time by watchdog timer. It does not make autosupout file.
I have contacted support and send them supout.
Anybody has seen something similar?
Pedro
Yes ! I have the same isue. Now downgrading to 4.03. On two other RB600 boards this problem does not exist (work stable on 4.04 in two weeks)
After change router reboots at couple minutes frequently.
Same config, same bios, two identical RB600A.
I don’t now where the problem is (no supout generated as you wrote).
