RB600 LAN damaged
Please tell me what should I replace on the board to repair my LAN1 port?
PoE works fine but there is no LAN transmission over LAN1.
I see there is a RTL8212-GR as a PHY under the radiator.
Is it everyting I need to change? :slight_smile:
You can separate utp cable on two connectors one for PoE and another for DATA by hand because 2 pairs are DATA, another 2 pairs are PoE or You can buy one of this http://www.passivepoe.com/ …
Yes, carefully replace RTL8212 and that’s all. Some times D701,D702 can be dead but it’s not frequently.
Hello Folks!
Where can I get the RTL8212-GR and the protection diodes d701 and d702 ?
sales@mikrotik.com
