Hello
I have Rb600 installed,with four 2.4ghzsectores,some time my router will be stoped(down),we should reboot it munally then router will be work again so can tell me what is problem this is out put log in my router
Doc1.doc (43.5 KB)
kurd -
Not enough information… What version of ROS (i.e. 3.13 or 3.24, etc) are you using?
What are you using for your PoE voltage to run the RB600?
You really can not use four 2.4ghz channels and not have a lot of issues with dropped connections, lost beacons, disconnect due to extensive data, etc. There are ONLY three non-overlapping channels in the 2.4ghz spectrum…better re-think your wireless deployment.
R/
