RB600 Problem
i have a problem with a rb 600.
The RB600 is powered at 48 volts but sometimes automatically restarts, and writes:
router was rebooted withut proper shutdown by watchdog timer …
quancuno authority may help me?
I do not know what to do, is the only rb that behaves in this way.
Thx to all
You should disable the watchdog, go Watchdog System menu and uncheck the watchdog timer
Thank you very much for your reply.
I thought well I to this solution, but if the system goes into block should not restart since the watchdog is disabled. In this case, no risk of having to manually restart the station?
Unfortunately, is located 30 meters on a pole and if it were to stop, I need a sea of authorizations to access the site.
