RB600 processor
Sorry for the stupid question…
RB600 MPC8343E 266/400MHz network CPU means that its processor may work both at 266 and 400 MHz according to computational needs? :question:
Rgds
no, it means that it can be clocked at different speeds. We ship the boards with 400MHz
Thank you Normis,
might this be applied also to RB532/RB532A? I have both of them…
If yes, how this can be done?
admin@MIKROTIK_CASSISI] /system resource> print
uptime: 53m3s
version: “3.6”
free-memory: 40116kB
total-memory: 62588kB
cpu: “MIPS 4Kc V0.10”
cpu-count: 1
cpu-frequency: 399MHz
cpu-load: 100
free-hdd-space: 89012kB
total-hdd-space: 126976kB
write-sect-since-reboot: 873
write-sect-total: 81079
bad-blocks: 0
[admin@MIKROTIK_CASSISI] /system resource>
[admin@AdiessellePALMI] /system resource> print
uptime: 1h2m5s
version: “3.4”
free-memory: 9588kB
total-memory: 30144kB
cpu-count: 1
cpu-frequency: 264MHz
cpu-load: 100
free-hdd-space: 84904kB
write-sect-since-reboot: 733
write-sect-total: 65127
bad-blocks: 0
yes. you can actually change the frequency to a higher one if you wish.
thank you Normis, but… how can I change it? :sunglasses:
you can change cpu speed in /system routerboard settings menu if you have routerboard package installed
Thank you Alex,
I’ve done it, but frequency doesn’t change…It seems that I have the same problem described in http://forum.mikrotik.com/t/rb532-333mhz-how/15461/5:frowning:
you have to do folowing steps:
set cpu-frequency=399MHz
keep-frequency
Shutdown your board and do powercycle (turn off and on power)
Just connect the console to the board and on startup press any key to enter the BIOS - it is possible to change frequency settings there.
