RB600 Released
Mikrotik announced the RB600 to distributors this morning.
CPU MPC8343E 266/400MHz network processor
Memory 64MB DDR SDRAM onboard memory
Boot loader RouterBOOT, 1Mbit Flash chip
Data storage 64MB onboard NAND memory chip
Ethernet Three 10/100/1000 Mbit/s Gigabit Ethernet with Auto-MDI/X
miniPCI Four MiniPCI Type IIIA/IIIB slots
Expansion Daughterboard support, including RB500 daughterboards
Compact Flash Two independent CompactFlash slots (TrueIDE Microdrive supported)
Serial port One DB9 RS232C asynchronous serial port
Speaker Mini PC-Speaker
Power options IEEE802.3af PoE: 38..56V DC including over datalines.
Power jack: 10..56V DC
Fan control Two 5V DC fan power output headers with rotation sensor and automatic
fan switching (maximum output current - 300mA total)
Dimensions 14 cm x 20 cm (5.51 in x 7.87 in), 227 g (8 oz)
Power consumption ~9W without extension cards, maximum – 35+ W
Operating System MikroTik RouterOS v3, Level4 license
Brochure: http://www.quicklinkwireless.com/rb600.pdf
Pre-Order: https://www.quicklinkwireless.com/default.asp?pid=1185
We would also like to inform you that the manufacturing of RB532 (32MB RAM) has been discontinued and this model of RouterBOARD is not available anymore.
-Gerard
Edit: Only the RB532(with 32MB RAM) has been discontinued. The RB532A(with 64MB RAM) will continue to be manufactured.
So 802.3af is supported again after the rb192,rb133/c & rb333 not supporting more than 28v. :open_mouth:
And it doesn’t support less than 38V on POE? I’m not going to be able to standardize on one power supply ever again :confused:
Hopefully the Gigabit ports are more stable than the ones on the rb44G.
impressive..
It would be good for them to support 2.9x instead of only 3.0 .. im scared to give the new ros 3.0 a try after the bugs i read on the forum..
Nevertheless, 4mpci and 400mhz rocks…
PowerPC architecture so will never be supported under 2.9.
I’m very pleased to see full 802.3af support, now we should be able to pull power from an 802.3af switch. Well done MT!!
George
I’m wondering wether 4 cards on one board in one housing can
work without interfering each other.
RB600 would give the possibility to handle one uplink and
3 120degree sectors in one box.
Does this make sense using 5GHz?
Stefan
The IEEE 802.3af standard supports delivery of Power over Ethernet up to 15.4W per port that may be used to deliver power to a variety of devices (figure 1.) The IEEE 802.3af standard also defines the concept of power classes including a reserved class that may be extended to support increased power delivery to PDs in the future. As an example, this class may be expanded to support the power requirements of a laptop PC that typically draws much more than the 15.4W currently allowed for within IEEE 802.3af.
So your POE switch may not be able to power this device.
Not happy they are discontinuing RB532 because of this.
Atleast give us 6 months of a known working product before such is done.
Right now we don’t have a replacement for RB532 that is 100% tried and true in the field :frowning:
RB333 and RB600 are NOT at that point yet.
SMA
They only discontinued the RB532 and not the RB532A.
-Gerard
<< They only discontinued the RB532 and not the RB532A. >>
Oh…good…whew… :slight_smile:
Thanx…
SMA
Even so it would still make sense that as these new boards are V3 only that they didn’t discontinue products that work in favour of ones that are still at an RC stage.
shame,
look what froogle brings for rb600
http://www.google.com/products?q=rb600
What happened to the 600-666mhz cpu? Will using this board for a wireless bridge actually be better than a 532?
of course it will be. compare throughput:
http://www.routerboard.com/pdf/tests_dec_2007.pdf
Well. I’ll tomorrow install my first RB600 in a important location, where was 532 before. Wish me luck. :slight_smile:
What do those numbers indicate? pps? mbit/s?
that is pps , u have to calculate mbit… I wonder why!
because of test method, we get test resaults in pps, so we post them as is.
Hi all
This is perhaps off topic, but I decided to ask anyway due to the fact that the RB600 specs are being discussed over here.
What I need to know, is wheter you can install MT on a CF using the RB600. I have tried this with an RB532A, it didn’t work, I contacted MT support and they said it won’t, as the board was designed in such a way that MTROS can only be run from the NAND.
What I ideally would like to do, is to install MTv3.1 level6 on a CF, and use the second CF slot for Usermanager data. The main and most important reason for this is in order to run the UM off a 12VDC battery backup.
Our South African power provider ran into magor problems and apparently we’ll have to live with these problems for years to come. Some days we have power outages for 2 to 4 hours in one go, usually at the peak hours for business. Our entire system is on battery backup, highsites, core routers, switches, PSTN routers etc, only UM is not.
Any help on this will be appreciated.
Regards, Giepie
no, RouterOS can only be installed on a NAND
NAND and CF take about the same amount of power I am guessing… and neither of those take power directly, it’s the routerboard itself. Whats the goal ?
